Signal Conditioning
niDMM_configureMulitPoint problem
My software : NI-DMM 2.5, NI-SWITCH 3.0.49161, NI-DAQmx 8.0.0f0, NI-VISA 3.4, VC++ 2005 Express.
My hardware : PCI 4070, SCXI1000, 2 SCXI1127, SH9MD-AUX cable and SCXI 1359 kit.
I am trying to implement synchronous scanning betweem DMM and SCXI. This code:
status=niDMM_ConfigureMultiPoint( viDVM
,iSampleCount,1,NIDMM_VAL_INTERVAL, 0.1 );
niDMM_GetAttributeViReal64( viDVM, VI_NULL, NIDMM_ATTR_SAMPLE_INTERVAL, &dInterval);
MyPrintf("Read Interval I: %.2lf", dInterval );
..produces value of -1.( dInterval)
It seems to be scanning my 16 channels fine, but I cannot force the DMM to wait to allow for the time needed for the switch to activate and settle. The speed is purely driven by DMM's integration time. If I set it very fast I am pretty sure there's not enough time for the switch to switch and settle ( 10 ms? ).
Any help will be appreciated,
Thank you,
Jerry.
(3,541 Views)
It seems that you may have already answered this question as you have created another post regarding handshaking between your switch and DMM.  I am going to address this issue in the other discussion, found at the link below:
Handshaking Scanning with PCI DMM and SCXI
Jason S.
(3,511 Views)
Yes, this problem is solved,
Thank you,
Jerry
(3,506 Views)
