Signal Conditioning
reverse direction of analog feedback
Dear All
I have a motion system, where I switch between position control (encoder) and load control (analog feedback).  I have many transducers that are wired and to use on the system.
My problem is, that when in analog feedback, the transducers drive the motor the wrong direction and thus without any control as the system becomes unstable.  If I simply swap the output signal from the transducer the system works fine.
Is there a way that I can do this in software either Labview or MAX.  I have not been able to find how and it is not a simple switch of polarity as the system is controlled at a low level by the PID parameters
Thanks for any help and I hope this question makes sense.
wayne
Message 1 of 8
(4,543 Views)
Hello Wayne,
What hardware are you using?
What kind of signal are you reading in?
What are you currently doing in software that drives the motor the wrong way?
Have a great day!
Marni S.
Message 2 of 8
(4,526 Views)
Marni
I am reading a load cell and driving a motor based on that.  The problem that I am having is that the motor drives the opposite way to the feedback - this I thought would be a relatively simple swap of some setup bit and get on with it.  I have though had an email from NI in Germany - Jochen Klier, who stated that it is not possible to achieve what I am after.
As such, I had already thought about having to make an inline cross-over plug that would simply reverse the signals on the transducer without having to rewire the transducers.
The hardware I am using is both the PCI 7344 and PCI 7354 motion control card.
I must also apologise for my post ending up on the signal conditioning group.  It seems that firstly the email was deleted then sent to the incorrect list.
wayne
Message 3 of 8
(4,519 Views)
Hi wayne,
I don't see any way of swapping the polarity of the analog feedback or the PID output in software. Is there a reason why swapping the hardware lines is a problem for this applications?
Nipun M
Motion and Vision Group
Message 4 of 8
(4,511 Views)
Nipun
There is no real problem with swapping the signal lines in our transducers, as mentioned earlier by way of an inline plug will achieve this.
I was just thinking that if I could achieve it in software then I would.
wayne
Message 5 of 8
(4,507 Views)
Hi wayne,
I've been looking for possibilities, but unfortunately don't see any viable way of achieving this in software. I was concerned if this is a remote system that might make it difficult for you.
Nipun
Message 6 of 8
(4,494 Views)
IF you read the sensor with a custom channel , created in MAX , why it's not possible to change the sign?
Isn't it possible to enter a negativ m (-1) in the custom linear scaling?
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 8
(4,487 Views)
Another option may be if you had a spare digital output to fire a double pole double throw relay (DPDT) you could have the relay swap the polarity
Message 8 of 8
(4,483 Views)
