Signal Conditioning
scxi 1100 analog output
I use an scxi 1100 to acquire some temperatures of 25 termopars. The system is working well, but now, I have to send one signal to control the system. Is it possible to use the scxi 1100 to output an analog voltage signal?
(3,576 Views)
IF the DAQ device you have cabled to your SCXI chassis has analog output channels AND you have an available slot in your SCXI chassis, you can purchase an SCXI-1180 feedthrough module that will grant you access to the unused lines on your DAQ device. Take a look at the product page and user manual for the SCXI-1180 for more information.
Molly K.
Applications Engineering
Molly K.
Web Support & Operations Manager
(3,576 Views)
My board is an ATMIO-16E, and it has 2 analog outputs. But I want to know if it´s possible, using the rear conector, to send the signal.
(3,576 Views)
