Signal Conditioning
single power supply for OpAmp
I have been trying to test the TLC272 OpAmp with single power supply as the attached circuit, but measured no output.   Any hints would be appreciated!
kkwan
Anadig
(6,515 Views)
Accepted by topic author kkwan
if you post the circuit as an png I might be able to read it and give an answer 🙂
Greetings from Germany
Henrik
LV since v3.1
(6,505 Views)
Thanks Henrik. Problem has been solved!
K. Kwan
Anadig
(6,501 Views)
