Signal Conditioning
waveform cannot be transferred to computer from the oscilloscope
I just bought a Tektronix TDS 2001C oscilloscope that came with “NI Lab VIEW SignalExpress Tektronix Edition software. I installed de software in a laptop computer with Vista operating system. The installation process seemed to be successful. I connected the oscilloscope to the computer with a USB cable form the back of the oscilloscope. When I ran the software a guide prompts me to do the following to view the waveform displayed in the oscilloscope. “Click Add step – Acquire Signals – Daqmx Acquire – Analog Input – Acceleration” But when I click “Add step” and “Acquire Signals” there is no “Daqmx Acquire” option. There is only °IVI Acquire” and “Shared Variables” options. Whatever I choose the result is always “NO Device” So I cannot see the waveform in the computer.  Please, can someone help me? Thank you in advance.
(5,810 Views)
Actually, you must use the IVI Acquire step. You must also have NI-VISA installed on your PC.
Try IVI Acquire and let me know if that worked!
Regards!
Felipe Flores
Technical Support Engineer
(5,746 Views)
Dear Felipe:
I will do what you suggest and will let you know if it works. Thank you very much.
Francisco Skala
(5,738 Views)
