Signal Conditioning
what is the maximum analog output voltage we can get from available SCXI module?
I am using SCXI 1001 Chassis. I want to get high analog output voltage (in the range of kV) from any of SCXI module. Is it possible to get such high voltage from any module,if it is name the module.Or what is the maximum analog output voltage we can get from analog output SCXI module?
(6,011 Views)
You are going to need to put DC/DC converters on each line where you want that kind of voltage. Such as this one. Search NI for SCXI modules. Typical outputs are 10V.
Richard
(6,004 Views)
