Signal Conditioning
working with SCXI 1520 & BNC 2080
I'm working with SCXI 1520 with 1314 terminal block.
I'd like to acquire signals coming out from SCXI and (in the mean time) signals from BNC 2080 linked with a strain gage conditioner (Vishay).
Is it possible; and how?
Thanks you very much.
Stefano Sensi
(3,249 Views)
Stefano,
This should be possible. When using the SCXI-1520 in multiplexed mode, only differential channel 0 of the controlling DAQ device is used. So, you can access the remaining analog input channels with your BNC-2080. However, there are a couple of important things to keep in mind. First, because the SCXI-1520 is a parallel-capable module, you will be unable to accomplish this with a SCXI-1349. You will need to use a SCXI-1346. This is explained in detail in the KnowledgeBase linked below:
Can I Use the SCXI-1180 Feedthrough Module with a SCXI-1520 Module?
So, you will connect your BNC-2080 to the 50-pin connector on the SCXI-1346 via a 50-pin cab
le. I have also included a link to a KnowledgeBase with the SCXI-1346 pin translations:
Breakout Pin Translations for the SCXI-1349 and SCXI-1346
Good luck with your application.
Spencer S.
(3,249 Views)
