Signal Conditioning
write digital output
I have a 6152 card and I would like to now how to make a digital output from change state for n times using the card internal clock.
I'm using V.B. 6 to program .
thank you
(3,354 Views)
I suppose the board you are using is a M series board.
Then you will need to call DAQmx drivers from VB6.
It is possible with the DAQmx 7.5 drivers. You will find more details on the subject here :
http://digital.ni.com/public.nsf/websearch/B22FE2B0F9C8935286256E920073DA07?OpenDocument
regards,
Marc L.
NIF
(3,316 Views)
