Signal Conditioning
wrong voltage value using SCXI-1305
I´m using SCXI-1305 and I want to measure a voltage value, but every channel shows the a floating value of aproximmately 0,00025 V instead of the true value
(3,258 Views)
SCXI 1305 is your terminal block
which is yourm SCXI module?
plus check two more things
  • Gain/ range settings that you have selected
  • The state of the switchable AC coupling and Ground reference on your SCXI1305 T block
hope this helps
Regards
Dev
(3,250 Views)
