Signal Generators
100Hz to 8kHz Sine waves generation
I need to generate 8 different variable frequency sine waves. The frequency are between 100Hz and 8kHz and the precision should be 1Hz.
With the PXI-6713, I could change the update frequency to change the output frequency, but it seems that we can have only one update frequency for all the channels even if I use an external update clock.
I could too play with the buffer to generate different frequency but I think I will not easy to change dynamicaly the frequency on more than one channel.
An other solution is to find another hardware to generate different variable frequency on 4 or 8 channels.
If anybody has a suggestion or reference, I will appreciate
(7,811 Views)
Hi hrobitaille,
Go with your "play with the buffer" approach.
The alternative would be to buy 7 more boards.
Ben
(7,811 Views)
