Signal Generators
Constellation plot
Heloo
My question is can i plot constellation plot in graph or XY graph of Labview without using modualtion toolkit "Constellation plot" or any other took kit.  i am using labview 8.5 evaluation version.Also asnswer how can i.
Regards
 Madd
(14,125 Views)
Hi madd,
You can create something similar to a constellation plot by wiring your data into an XY Graph or Waveform Graph or Chart. Then right click on the graph or chart and select Properties. Go to the Plots tab and change the line type to None.
Hillary E
(14,118 Views)
Hi Madd,
Modulation Toolkit has two different types of visualization: 1) IQ Graph which is simply the XY representation of the In Phase and Quadrature Phase samples. This can be acomplish as follows:
2) Constellation Plot has two plots in the same graph: the symbols (points) and the transitions. Therefore it knows the timing of the baseband data.
Message Edited by Yardov on 02-16-2008 10:02 AM
Gerardo O.
RF SW Engineering R&D
(14,106 Views)
Hello
I am trying to make a program for 8 PSK Modulation but not able to make it. Can you please help me with the program for 8 PSK modulation.
Harsh
(9,179 Views)
Hi Harsh,
You are going to want to use the Modulation Toolkit. This is not strictly necessary, you can always develop the modulation on your own, but it makes it much easier. You may already have the Modulation Toolkit on your computer, it comes with the RF Device Drivers.
You may also have more luck posting in the RF Measurement Devices Forum.
Cheers,
Michael
Michael Bilyk
Former NI Software Engineer (IT)
(9,167 Views)
And if you want to know what VI you should use for PSK, MT Modulate PSK and MT Demodulate PSK will help.
Michael Bilyk
(9,166 Views)
