Signal Generators
Generating a single pulse with the PXI 5412
I'm creating an arbitrary waveform that is a square wave from 0-5Volts.  I only want this square wave to be outputted as a single pulse and that's it.  The 5412 keeps repeating or cycling back this waveform that I have generated so I get a pulse train, which is not what I want.  Is there any way that I can output just a single pulse?
Thanks for your help.
(8,795 Views)
Set the trigger mode to single.  By default it is continuous.  And if you want the pulse to be output 7 times, set trigger mode to single and repeat count to 7.
Neil F.
Neil Feiereisel
Principal Engineer, Modular Instruments, National Instruments
(8,788 Views)
We are wanting to do a similiar thing with the PXI-5412.  How do you specify the repeat count?
(6,321 Views)
Where are the trigger modes (and their integer values) defined? Are these correct? They are from an NI white paper called "Triggering Modes":
1. Single
2. Continuous
3. Stepped
4. Burst
http://www.ni.com/white-paper/4360/en/
(5,919 Views)
This information can be found in the NI-FGEN User manual.
Here is a link to the HTML version of the NI-FGEN User manual to the page that describes these triggering modes: http://zone.ni.com/reference/en-XX/help/370524R-01/TOC45.htm
Please create another thread if you have more questions.
Jason L.
Product Support Engineer
(5,915 Views)
