Signal Generators
HSDIO gen clock to one channel
Hello, everyone. I beginer in LabVIEW. Can you help me? I work with HSDIO PXI 6555 module.
How can i do that on the one channel will be generated clock (and after close session too)?
(5,788 Views)
6555 generation example is available in Help>>Find Examples>>Hardware Input and Output>>Modular Instruments>>NI-HSDIO (High-Speed Digital I/O)>>Dynamic Generation. However, you must keep the session open in order to generate the clock.
(5,780 Views)
