Signal Generators
How can I get the CLK OUT using PLL on NI PXI-6652?
I am try to get the CLK OUT using the source CLK from internal either DDS or PXI_CLK10_IN and PLL to the required frequency. In other words I want the CLK OUT coming from the NI PXI-6652 to be PLL to required frequency.
Ashok
(7,242 Views)
 Hi Ashok,
What frequency are you trying to PLL to?  Do you have a second signal which you want to PLL your CLK OUT with?  If you generate the DDS Clock on board then it will be generated at your chosen frequency, and PXI_CLK10_IN is a 10MHz chassis controlled signal you can override with the 6652 card.
Kyle A.
Senior Applications Engineer
(7,226 Views)
I am trying to PLL 8.192 MHz clock. Yes, I have generated the clock from DDS at chosen frequency. But instead of routing to CLK OUT can I route to PXI_CLK10_IN?
(7,210 Views)
Accepted by topic author Solanki
Unfortunately, there is no direct route in hardware to get the DDS clock to PXI_CLK10_IN.  Typically, PLL is used for external signals which are out of phase with the system, and not for internally generated signals.  Coming from the 665X User Manual online, here is a functional overview of the board:
Kyle A.
(7,206 Views)
I agree that just confirming. So I decided to route the generated DDS clock at chosen frequency to CLK OUT.
(7,204 Views)
