08-17-2006 07:35 AM
08-18-2006 04:33 PM
Hello supermango,
I believe what you're trying to do is AO without regeneration. You should be able to do this. I recommend starting with the "Cont Gen Wfm Int-Clk Non-Regeneration.vi" and setting up a case structure inside the loop that allows you to select between a sine wave array and an array with 1 set point of data. It will continue to send the value untill you update it or select the sine wave.
Hope this helps,
Andrew S.
