Signal Generators
How do I Turn the RF On using the labview driver?
Don't start multiple threads!
I didn't. I started one thread and then after searching on the subject,  added a reply to someone elses thread who was obviously having similar trouble to me but on a different instrument supported by the same driver.
Also, It is the pnp driver, not IVI.
Thanks.
Message 11 of 12
(3,393 Views)
Found the problem.
When a MXG series Sig Gen does not have the modulate output option installed in the instrument and the labview pnp driver trys to set its state with  OUTP:MOD OFF, an error is returned.
The driver needs to check if it the option is fitted before sending the command.
Message 12 of 12
(3,355 Views)
