Signal Generators
How is an RGB32 image formatted?
I have a NI PCI-1411 analog card connected to a color NTSC camera. I would like to know specifically how the RGB32 image is encoded. I have figured out that each pixel is 32 bits and that there are four "channels" of 8-bits. What I really want to know is what is in each of the four channels. Where are Red, Green, Blue, and what is the fouth one?
(11,975 Views)
Hello.
The answer to your question is essentially the following:
Least significant 8 bits: Red
Next 8 bits : Green
Next 8 bits : Blue
Most significant 8 bits : Not Used, or used for transparency (alpha)
I have attached a snapshot of a LabVIEW VI that descries this visually as well.
For more information on transparency, see the following KnowledgeBase:
http://digital.ni.com/public.nsf/websearch/00736861C29ADFB786256D120079D119?OpenDocument
Hope this helps!
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(11,975 Views)
