Signal Generators
How to replace 5411 with 5412 AWG with minimal pain
I developed a LabWindows 8.0 application driving a number of boards with DAQmx calls and a 5411 AWG using nifgen calls on a PXI chassis.  I have a colleague who wants to use the source code with the same hardware except the 5411 has been replaced with a 5412 AWG.  Can I just rename the 5412 device in MAX (listed in DAQmx folder) as DAQ::6 (how I see the 5411 as a traditional DAQ device)?
Message 1 of 9
(9,057 Views)
Yes, you can rename the 5412 in MAX - just change the name in MAX to "6" (with no "DAQ::" in front of it) - and the existing code will be able to open a session to the 5412 using "DAQ::6" as the resource name.  Hopefully everything else just works!
Drew Creel
NI Software Engineer
Signal Generators Group
Drew Creel
NI Software Group Manager
RF and Signal Generators
Message 2 of 9
(9,041 Views)
Your application may just work with the new hardware, but there are some slight differences between the 5411 and 5412.  Here is an NI KnowledgeBase article entitled "Transitioning Applications from NI 5411 to NI 5412" that describes the differences between the two devices.
Evan Cone
RF R&D
Message 3 of 9
(9,030 Views)
The link provided to the documents above describing the 5411 and 5412 differences does not work.
Can you provide a working one?
Message Edited by SIMTECH on 04-22-2008 01:00 PM
Jeff
Message 4 of 9
(8,325 Views)
SIMTECH,
I was able to navigate to the above link.  Here is the actual address of the article, please post back if you are still encountering difficulties.
http://digital.ni.com/public.nsf/allkb/da8b12f6b744a3db86256f7100749b09
Ryan N
Application Engineer
ni.com/support
Message 5 of 9
(8,306 Views)
I was referring to the two document links on thhe page.
When I try and download either of the two .doc files:
"Features Supported..."
"NIFGEN Functions..."
I get an error.
Jeff
Message 6 of 9
(8,298 Views)
SIMTECH,
I was able to also download those documents on my machine.  I have posted them below for convenience.
I hope this helps!
Ryan N
ni.com/support
Message 7 of 9
(8,295 Views)
That works.
Jeff
Message 8 of 9
(8,290 Views)
Ryan,
The links to the .doc files on that page are to .ae. and us normal folks can't access the application engineer pages.Smiley Wink
Message 9 of 9
(8,283 Views)
