Signal Generators
Is there any optiont to write the signal generated using AWG NI-RFSG 5670 GENERATOR to a file in Notepad or Spreadsheet or any other format???
(6,943 Views)
Hi
I'm not sure what you are asking.
Are you asking if you can create the waveform in Notepad or Excel, and then write the waveform to the NI 5670?  Or do you want to write a waveform, previously created with Modulation toolkit, that is generated by the NI 5670 to Notepad or excel as a copy?
J
(6,937 Views)
HI JERRY,
                 FIRST WE USE BASEBAND TRANSMITTER TO DUMP THE WAVEFORM PATTERN INTO THE MEMORY OF AWG (NI-RFSG 67) RIGHT.
THEN WE CONFIGURE THE RFSG TO GENERATE THAT WAVEFORM RIGHT AND ANALYZE IT IN RFSA-DEMO PANEL RIGHT.
WHAT YOUR SECOND QUESTION IS WHAT WE REQUIRE.I MEAN WE WANT THE SIGNAL GENERATE BY AWG(NI-RFSG 5670) TO BE WRITTEN INTO NOTEPAD OR SPREADSHEET OR IN ANYFORMAT.
(6,925 Views)
Hello Particlereddy,
The NI RFSA Soft  Demo has the capability to save the spectrum acquired to a .txt file. The bottom right corner has  the save button that will allow you to save the spectrum. From what I understand you are using the RFSA to view the waveform; you could save it as well in  a .txt file. Please let me know if this does not answer your question.
Ayman K
(6,898 Views)
