11-08-2001 09:22 AM
11-12-2001 08:55 AM
03-01-2006 05:02 AM
03-02-2006 11:47 AM
Hello Jeremy,
Can you be more specific about your setup? If you have a grounded source, you set the switch to gs and connect your BNC cable with the positive lead and negative shield from your source. The BNC 2110 will disconnect the switch to AI ground internally so that no ground loops occur. You do not have to disconnect the shield. Your DAQ device needs to be configured in software as differential, and the positive lead will connect to AI+ and the negative shield will connect to AI-. I think that the figure should not be disregarded.
Let me know if you have questions.
Laura
03-02-2006 01:07 PM
03-03-2006
11:25 AM
- last edited on
11-10-2025
11:29 AM
by
Content Cleaner
Hello Jeremy,
When using differential mode with a floating source, we recommend that you use bias resistors for a few reasons. There is an extremely good Field Wiring and Noise Considerations for Analog Signals tutorial that explains these considerations, so I will refer you to it, rather than try to explain it myself.
