Signal Generators
Not able to load files generated using Ni DWE Tool set into FGEN Soft Panel!
Hardware is PXI-5421
While i am able to generate digital waveforms in the Digital Waveform
Editor
Toolset and save it, the same shows and error reading file:
"some data is invalid, check for corruption"
To read the file in *.hws format i am using NI FGEN Soft Front Panel
supplied
by NI.
When i load the example waveform from location
C:\Program Files\National Instruments\LabVIEW
7.0\examples\instr\niHSDIO\Support Files\Mywfm.hws
FGEn throws up error:
"The data type of this trace is not supported. Currently supported
data
types
are 8, 16 & 32 bit signed integers."
Software Details: Other version N/A
NI Hardware : Signal Sources (AWG/Function Generators) device PCI-5421
Driver Version : 2.1
Operating System: Windows 2000
Customer Information
sunil raj
Apna Technologies & Solutions
Marketing
1 coconut garden, Outer ring road,
BANGALORE,
IN
560043
IN
Message 1 of 1
(6,373 Views)
