Signal Generators
OPC with tkawg5k7k
A have an application where I need to load bigs waveforms between tests from HD to the memory of teh AWG5002 it take diferent time
to load depending of the waveform. I need to wait untill the wave form is loadded prior to enable the signal out.
I can do that by delays but i would like to do by asking the instrument by the OPC when it is ready.
Do someone know how to doit. It seems as the tkawg5k7k driver doesn't suppot the call wait for OPC.
Thanks for help.
Regards
(6,004 Views)
I don't think OPC support this signal generator, but you could try using its instrument driver found in http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=5F5A66F363C32A8FE0440003BA7CCD...
(5,835 Views)
