Signal Generators
PXI 5421 Using iviFgen LabVIEW VI Example Has No Output
I'm having trouble getting a PXI 5421 outputting a waveform. The Instruments Studio and the Soft Panel work fine. I get a nice output to an oscilloscope. However, when I run the iviFgen[ARB]-Generate Arb Wfn.vi example that is provided in the "Help -> Find Examples", I get no output. It runs with no errors.
I've included a simple vi that I am trying to get working, which is very similar to the NI example. The module is running on a PXIe 1088 in LabVIEW 2020 SP1. Any thoughts on why the PXI 5421 will not generate an output in the vi? Thank you.
Message 1 of 1
(907 Views)
