Signal Generators
PXI-6733 On-Fly Analogue Output Update
Hi, we were going to use a PXI-6722 card to generate 7 different analogue outputs.... but reading through this forum it seems that this is not possible with the 6722 due to it's serial DAC.
The PXI-6733 looks to be a better option in that it will be able to generate 7 different analogue outputs but my question is can these outputs be updated 'on-fly' without having to stop the existing outputs first?
Steve
(5,985 Views)
Hi there Steve,
Take a look at this post and see if it's of use to you. If it is, or isn't, then post back and let me know.
http://forums.ni.com/t5/LabVIEW/Changing-AO-during-runtime-while-other-AO-continue-to-run/m-p/988395
Have a great weekend,
Rhys
(5,965 Views)
