Signal Generators
Please,
I'm looking for a multi-channel (i.e. 6713 board) waveform generator LabVIEW example and/or a kind of waveforms editor (even very simple, of file import capability). The waveforms generator should be able to play a waveforms buffer at once or continuously.I'd like to receive pieces of LabVIEW code regarding both waveform generation (for istance, on the 8 6713 output channels)and waveforms edit, even in separate programs. Thanks so much in advance for your help
(6,690 Views)
I'm looking for a multi-channel (i.e. 6713 board) waveform generator LabVIEW example and/or a kind of waveforms editor (even very simple, of file import capability). The waveforms generator should be able to play a waveforms buffer at once or continuously.Hello;
There is a set of good analog output examples you can refer to. You can find those examples at Labview->Search Examples->Hardware Input and Output->DAQ->Analog Output.
You can freely modify those examples and even combine those to meet your applications needs.
Hope this helps.
Filipe A.
(6,690 Views)
