Signal Generators
RFSG Generate PSK: IQ Rate Error
We are using NI-PXIe-1075, Signal Generator module NI PXI 5652. We want to transmit a BPSK signal so we used the LabView example MT RFSG Generate PSK.vi. We tried using the default values and we also tried to change the input values many times but we keep on encountering the error found in the screenshot attached. Do you know any possible reason for this? Thank you.
(3,781 Views)
Hello!
It looks like that example is not compatible with the PXI-5652. Please refer to the screenshot I've attached below.
However, it looks like there are some modulation examples available, in the folder "Modulated Waveform Generation." See the screenshot below.
Does this help?
Stephen
(3,701 Views)
