Signal Generators
Read From Measurement File and change the output frequency
Hi. How can I` change de output frequency of a signal obteined fron Read From Measurement File with the program runing.
I` made this Vi and I´need to change the frequency with the program runing.
The Scaling and Mapping use the %SpO2
The Read From Measurement File use all other lvm files
Other problem do i`have is I`can´t change de selected signa on the fly.
Regards
Sebastian
(5,836 Views)
You may want to look into non regeneration mode
-Ciao
(5,757 Views)
