Signal Generators
Script generation error
Hello All,
Im trying to generate a wave using  RFSG script generation Vi .
Im getting this error. Error -1074117667 occurred at niRFSG Initiate.viPossible reason(s):
This combination of attributes is not supported.
You cannot set the Power Level Type to Average Power in Script mode. Either change the Power Level Type to Peak Power or use the Arb Waveform Mode.
Thanks in advance,
prads
(6,589 Views)
Hi Prads,
What are you trying to generate with your script? How are you generating this? Also, what parameters are you defining for your generation (frequency, power level)? Please give us more information about the details of your application or maybe a screenshot could also be helpful. I'm asking these questions because it seems the error is related to the Power Level Type currently selected, so with more information we might be able to help you better with this issue. Have a nice day,
Ana P
(6,562 Views)
