Signal Generators
There are no llb files in the hp8165a zip file . What can I do?
Missing files in the zip file. Cannot run the downloaded file for the HP 8165 A programmable Signal Source
(6,471 Views)
The reason there are no llb's included is because this instrument driver is written for LabWindows CVI and not LabVIEW. However, if you like, you can use a wizard in LabVIEW to create a LabVIEW llb that could then be used in LabVIEW. The wizard can be found in LabVIEW at "Tools » Instrumentation » Import CVI Instrument Driver...".
Hope this helps!
Steven B.
Application Engineering
(6,471 Views)
