Signal Generators
Using PCI-5411 with Windows 7
As WinXp is not supported by Microsoft any more, I need to replace the PC running my experiment with a new one running Win7.
Is it possible to drive the NI-PCI5411 under Win7? On the topic, I have found some ambiguities in different documents:
in this one
https://download.ni.com/support/softlib/Signal_Generators/NI-FGEN/NI-FGEN%2016.0/readme.htm
NI-5411 is listed as compatible with Win7(64 bit) and reported in the list of compatible hardware.
Somewhere else, like here https://www.ni.com/en/support/downloads/drivers/download.ni-fgen.html#307113
it is written that is compatible only with WinXP.
At the end, can I use NI-5411 with Win7 (and Labwindows/CVI 2013)?
Regards
(4,215 Views)
Accepted by topic author llobs
Hi llobs,
The NI-PCI 5411 is not compatibile with Windows 7. Furthermore the NI 5411 has reached EOL/Obsolescence in 2004.
I see the ambiguity you mention in the readme you have posted and have filed a Corrective Action Request to fix this documentation issue.
Jason L
Product Support Engineer
(4,191 Views)
