Signal Generators
Using rb_visa gem to connect to HMC 8042 power supply unit
Hi, I'm trying to connect to a HMC 8042 power supply unit using the rb_visa ruby gem. When i try to disconnect and reconnect my ruby aplication to the psu, always on the third try i end up getting a coneection error (VI_ERROR_INV_OBJECT), which aparently means that there is an session already open to the device, however the only machine connected to it in my local network is my own.
Do you guys have any tips for that?
(3,300 Views)
Hi jups,
I answered this same question on this thread. Could you check that out?
Thanks!
Felipe Flores
Technical Support Engineer
(3,278 Views)
