Signal Generators
Using the PXIe-5413 100MHz clock as an external clock for the PXIe-6124
I'm using a 5413 Generator (100 MHz Clock) and a PXIe-6124 (80 Mhz Clock) for data aquisition. It's difficult to synchronise them because 100 Mhz is not an integer multiple of 80 MHz.
Is it possible to use the 100 MHz from the 5413 as the reference clock for the 6124? If not maybe the other way round and having 80 MHz on both?
Patrick
(2,511 Views)
(2,447 Views)
