Signal Generators
Variable frequency sine wave generation (software trigger) using PXI-5412
Hi All,
I am trying to generate a continuous sine wave (varying frequency) using a PXI-5412.
I need to make the frequency changes without switching the output OFF, i tried doing this in a loop but comes out with an error.
From the documentation, i figured that this can be done using frequency list and a time or software trigger?. I am having no luck trying to find the software trigger option. I was wondering if any one of you could give me some guidance please?
thanks and regards,
SS
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(6,889 Views)
Hey aCe,
This knowledge base article might help you, http://digital.ni.com/public.nsf/websearch/DD8C61F8AA83DAAE86257037007607C6?OpenDocument
Your card does not support scripting however the Burst Mode Triggering may help.  There is also an example attached.
To use a software trigger, place a normal trigger function down and select Start > Software Edge.  The trigger function can be found at Instrument I/O > NI-FGEN > Configuration > Configure Trigger & Synchronization > niFgen Configure Trigger (poly).vi
Let me know if this solves your problem or not.
Kind Regards,
Dominic Walker
Cardiff University
Electrical and Electronic Engineering Student
(6,856 Views)
