We unfortunately don't spec what the overvoltage protection or the backvoltage protection is on these cards.
If the spikes are just that...short duration spikes...then the outputs can handle a decent amount of voltage on the pins without suffering permanent damage.  So if something caused the outputs to bump up to 15V for very short periods of time, then I think any AO will be fine.  Usually, the problem with short circuit protection and things like that is the heat dissipation that occurs over a longer period of time.  If the AO were trying to output -10V and you tie that pin to +15, then quite a bit of power gets dissipated in our AO buffer and it will eventually overheat and fry.  But if the spike is really short then things don't get too hot.
The other condition you want to avoid is latchup.  If output pin gets driven hard enough above the (15V) rail, then you can induce parasitic transistors in the silicon that cause a rail-to-rail short.  In that case, removing the offending voltage does not reset the situation (you have to cycle the power in oder to turn off the parasitic transistor) and the part will fry shortly.  The following helps explain this situation:
 http://www.analog.com/library/analogDialogue/archives/35-05/latchup/
So the bottom line is we don't have a spec for overvoltage and I don't know what those numbers are without measuring them, but if you stay within +/- 15V, then short-duration spikes are okay.
If your device needs repair, the repair procedure is as follows:
1. Go to www.ni.com/ask to create your own Service Request number (SR#).  Choose the Phone NI option.  Fill in the form with the appropriate information.
2. Call the support number that is given to you and enter in your SR#.  You will be directed to an Applications Engineer (AE) that will assist you through the process.  The AE will be able to answer any questions you may have about the repair process.
Anyway, sorry I couldn't be of more help.  Have a good day.
Ron
