Signal Generators
What’s the ramp technique?
Hi All,
I would appreciate it if somebody can explain to me what’s meant by the ramp technique and how can you use it to plot the frequency response of a filter?
Marwan
http://www.geocities.com/marwan_m13/weemee8080.jpg
(7,519 Views)
Hi Marwan,
I'm not entirely sure what you mean by 'ramp technique', I have a few possible ideas for what it might refer to.
Could you point me to where you read about it?  From there I should be able to help you.
Sheela Sujeeun
National Instruments UK
(7,495 Views)
Marwan,
I've discovered what's called the Ramp Response (and this is what I initially thought you meant by Ramp Technique)
It is similar to creating the impulse response of a system, but you applying a unit ramp instead of an impulse to excite the system.
does this help?
Sheela Sujeeun
(7,488 Views)
SheelaS
The exercise is to determine the cutoff frequency of a low pass filter by using the ramp technique.
Marwan
Marwan
(7,482 Views)
Marwan,
I think you mean to use a frequency sweep, we have some information about this on our website here: http://zone.ni.com/devzone/cda/tut/p/id/2602
As there is still some ambiguity however, I would suggest you check with your tutor/mentor that this is the right idea.
Sheela Sujeeun
(7,467 Views)
