Signal Generators
Will the NI 5431(PXI) Video Signal Generator support SMPTE292M digital video format?
I need a video signal generator to provide a SMPTE292M digital video test signal. Can the NI 5431(PXI) do this?
(6,837 Views)
Hi RC MFR
The NI 5431 is unable to support the data rate specified in SMPTE292M. The maximum update rate of the NI 5431 is 40 MS/s. SMPTE292M specifies a serial date rate of 1.485 Gb/s.
Jerry
(6,836 Views)
Indeed the data rate of SMPTE292M is through the roof. I specialize in HDTV test systems and can help you put a solution together if you are still looking. Contact me at: www.wavetechservices.com
(6,725 Views)
