03-30-2007 01:56 PM
04-01-2007 10:03 PM
The system configuration you described should be ok. If you haven’t done so already, I would recommend trying to repair the installation (Control Panel>>Add or Remove Programs>>National Instruments Software>>Analog Waveform Editor>>Repair) in case any files got messed up on your system. If that doesn’t help, please post back with any details about the launch failure. Do you get any errors or do any windows come up or does nothing happen? Also, did you get any errors during installation?
Matt Kisler
Signal Generators R&D
04-02-2007 09:33 AM
I have unistalled and reinstalled and I have tried to repair the software.
When I try to start the program from the start menu, I get the little hour glass for about 3 seconds, then nothing happens. It shows up in task manager for about 2 seconds then closes.
If I try to start the program from the icon in the programs folder, the initial front panel comes up, but does not ever lauch the program. It shows up as a process in task manager, but does nothing.
04-02-2007 03:17 PM
04-02-2007 03:49 PM
04-03-2007 11:10 AM
04-04-2007 08:32 AM
04-04-2007 10:26 AM
04-05-2007 02:55 PM
04-05-2007 03:42 PM
