Signal Generators
can I generate Multicarrier Signal by the RFSG
Please, is it poosible to generate a Multicarrier signal by th RFSG?
(7,533 Views)
Hi Ahmed,
My tentative answer is 'yes', NI's RF hardware and drivers can to multicarrier generation. For instance, the DeveloperZone has an example for OFDM which is a multicarrier scheme [1]. What kind of signal are you looking to generate, and what are the characteristics of your carriers? Depending your exact needs, the application may become easier or more difficult.
[1] LabVIEW Modulation Toolkit OFDM Example
http://zone.ni.com/devzone/cda/epd/p/id/3456
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(7,520 Views)
Dear Joe i just want to know what is the minimum BW supported for OFDM Sub-Channels ? i'm asking her for various NI- Vector signal Generators available (2.7 GHz and 6.6 GHz system)
Can you help me please ?
Thanks in advance
Eng. Mohammed Ashraf
Certified LabVIEW Associated Developer
InnoVision Systems Founder, RF Test Development Engineer
www.ivsystems-eg.com
(6,993 Views)
