Signal Generators
driver hp-4142b
Yes, I have taken a two-day labview workshop from NI. The reason I am baffaled because I dont know anything about the instrument. And the connectivity between the instument and the labview, could not have been tested.
Thank you for your help.
Message 11 of 17
(5,070 Views)
Pratik,
If you are using LV 8 or higher this link will show you how NI provides for quick driver generation, which among other things auto-generates the code!
http://www.ni.com/swf/presentation/us/labview/projinstdrv/default.htm
Good luck!
Message 12 of 17
(5,033 Views)
Pratik,
I may have found some more driver helps for you in the form of possibly related 4142 drivers. The NI site has HP 4155/4156 drivers. Since the 4155/4156 and the 4142 are multi channel instruments, the 4155/4156 drivers may be a good point to start from for 4142 drivers. Also, probably best when looking for drivers to search for the model # under the mfg only. This should allow the best chance of finding all drivers that are available. I found the 4155/4156 drivers under Analyzer, but not Power Supply. I guess I was applying the IVI class names in this case and almost missed these drivers.
Message 13 of 17
(5,014 Views)
Hey, Deanosity
Thank you for the link and suggestion. It was helpful.
I am trying to use gpib-visa.VI gpib.vi examples and I am able to communicate using them.
Message 14 of 17
(5,008 Views)
hi pratik,
can you tell me what you did to communicate with 4142b via gpib?
Message 15 of 17
(4,810 Views)
Hello
I need help with hp4142b too. can you tell me how can I comunicate with hp4142b? thank you
Message 16 of 17
(4,294 Views)
Hello everyone,
I would like to know if anybody has developed the driver for 4142b since then?
Thank you.
Message 17 of 17
(4,150 Views)
