Signal Generators
frequency list with IviFgen class driver
Can i generate a frequency list using IviFgen function calls??. I saw that the IviFgenArbFrequency  group capability is not supported in NiFgen version 2.4.1. Is this capability supported in version 2.4.5??
(6,549 Views)
Hello
Frequency lists are not part of the IVI FGen spec - it's an NI-FGEN specific extension, thus you can only access it from NI-FGEN, see:
http://www.ivifoundation.org/Downloads/Class%20Specifications/IVI-4.3_FGen_v3.0.pdf
IviFgenArbFrequency extension is simply a way to specify a frequency in which to generate a waveform in Arb Waveform Mode.
I'm not sure why you want to use IVI FGen instead of NI-FGEN, since only some of NI's
Signal Generators (I'd be very surprised if another company's product implements something similar) have Ferquency Lists.
Marcos
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(6,538 Views)
