Signal Generators
generate a 10 bits monochrome video signal with 5421 board and VIDEO library
Hello all,
I use a 5421 for some video generation application.
Today, I'd like to generate a 10 bits resolution video signal in monochrome mode (for CCIR as well as RS 170 video format).
So, I tried to modify the example VI which is called : niVgen_Basic_Create_Composite_Signal_from_BMP_Image.vi. The input file is a 10 bits tiff format image and I defined the image that is used for generation as a 16bit image. The trouble is it doesn't seem to work. So my question will simply be : is it possible to generate a 10 bit depth monochrome image with 5421 board and the library i have. If so, what do I do wrong?
Thanks for help,
Sebastien DURAND
PS : I attach the vi as i tried to modify it.
Message 1 of 8
(9,006 Views)
Hi Sebastien !
You said you defined a 10 bits tiff image as a 16 bit image. Then don't you think the conversion occuring is a potential problem ? Did you try to convert neatly this picture and run the VI ?
Matthieu B.
NI France
Cordialement / Regards, Matthieu B. @ NI France.
Message 2 of 8
(8,993 Views)
Hi Matthieu,
Thanks for answering,
What do you mean by "convert neatly this picture"?
The fact is I tried to open the image i have generated, and it seems to work well when opened with 16 bits depth resolution ... but I am not sure at all the generation part of the VI is able to handle a 10 bits depth monochrome signal ... (video library???)
I join an exemple of a 10 bits resolution image and the VI that is able to open the image (which is exactly the same as what is done in the previous VI I sent), That means that for me the image is properly interpreted by LabVIEW ...
Sébastien DURAND
Message 3 of 8
(8,987 Views)
Nobody can help?
Sebastien
Message 4 of 8
(8,959 Views)
Hi Sebastien,
Sorry I can't help, but what is this 'Video Library'?  Is this from the VideoMASTER software tools, or something else?  I'm looking to generate composite video using a 5421 but not sure what tools exist to do this....any idea?
Todd
Message 5 of 8
(8,021 Views)
The VideoMASTER generator software can be downloaded from:
http://joule.ni.com/nidu/cds/view/p/id/1211/lang/en
Christian Koefoed
PSE VideoMASTER and AudioMASTER
Message 6 of 8
(8,003 Views)
Thanks, I downloaded it an will test it out with a loaner PCI-5421 next week.
Do you know if it works with a PCI-5421?  NI's site doesn't offer the video generation version of VideoMASTER with a PCI-5421, only with a PXI-5421.
Todd
Message 7 of 8
(7,993 Views)
Hello Todd,
Yes the VideoMASTER Generator software will work with the PCI-5421, even though on the website it is listed only under the PXI-5421. You will need to request an evaluation license from activate@microlex.dk which goes directly to the team that will issue you a temporary license (30 days).  Please include the serial number of the PCI-5421 in your email to activate@microlex.dk so they can issue the temporary license.
Finally if you are interested in purchasing the software, simply contact your local NI sales contact and request part number 780933-01 (VideoMASTER Generator SW only) be added to your purchase of your PCI-5421.
Let us know if you need any help as you get started with your evaluation, we will be happy to get you up and going.
Cheers,
Michael Schneider
Message 8 of 8
(7,983 Views)
