Signal Generators
how can I update the waveforms without using the rfsg abort.vi ?
i'm trying to generate a waveform multiple times with different contents ,   but i found that the RFSG need to use 'niRFSG abort.vi' everytime when i try to rewrite the waveform, and i also don't want to creat a new waveform cause it will waste large room of memory , how can i cover the old waveform with the new contents without use the abort.vi and write arb waveform .vi  again??
thx~~
Message 1 of 1
(5,457 Views)
