Signal Generators
how do i view the output of a simulated 5412 AWG
I simulated a 5412 AWG by using the string "Simulate=1,DriverSetup=Model:5412;BoardType:PXI;MemorySize:268435456" as the option string on niFgen Configure Output Mode.  I then created and ran the simulated device, apparently sucessfully.  But how do  I view the output (ch0) of the simulated device?
(5,311 Views)
You can't, since the device isn't real.
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(5,306 Views)
OK
I can also create FGEN Soft Front Panel via Measurement and Automation Explorer, which does display the simulated 5412 output, but I guess what you are saying is there is no way to connect this simulation with the Labview software simulation.
(5,300 Views)
