Signal Generators
how to create a waveform from an array with arbitrary sample rate
hi I know that sounds a bit silly,
suppose that I have created a simple array of DBL numbers with a For structure, with size say 16. now I want to create a DBL Waveform with these 16 numbers at an arbitrary sample rate. so if I use 1 Ksample/sec for sample rate, I wanna have a waveform with 16 milliseconds duration.
pls help me, I need it too much
TNX
(6,408 Views)
Accepted by topic author ehbas
You need to use the Build Waveform function as listed here: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/build-waveform.html . You would wire in your array to the Y input and then wire in your sample rate to the dt input.
-Zach
(6,387 Views)
