Signal Generators
how to create a waveform from an array with arbitrary sample rate?
hi I know that sounds a bit silly,
suppose that I have created a simple array of DBL numbers with a For structure, with size say 16. now I want to create a DBL Waveform with these 16 numbers at an arbitrary sample rate. so if I use 1 Ksample/sec for sample rate, I wanna have a waveform with 16 milliseconds duration.
pls help me, I need it too much
TNX
(6,384 Views)
So what exactly is the difficulty you are having? Do you not know how to set the sample rate? You have not provided the hardware or programming language you are using. Kind of hard to provide any kind of specific answer without that.
(6,380 Views)
it solved
I had just not seen the Build Waveform function from Programming Pallet.
(6,372 Views)
