Signal Generators
how to get a symmetric source signal which involved different 9 sinus signals
hello,
i 'm using labview 7.1 to simulate a interferrometric gyroscope.
so,i have a problem at getting symmetrice signal which consist of different 9 sinus signals.
this is the formula of a sinus source signal: Re[(2Po)½exp jwt)]
help plz
i am at this vi:
(5,808 Views)
cutkuc,
There are a few things that I notice while looking at your implementation.  If you are interested in Re{A*exp(jwt)}, then you would not create a sine wave and take the exponential of it.  Since
Re{A*exp(jwt)} = A*cos(wt)
In your code, you are already starting with a sine wave (which you might want to consider adding a phase delay to make it a cosine wave), then you take the exponential of it, which is making the wave appear with spikes.
I don't know much aobut interferrometric gyroscopes, but after deleting the exponential functions in your code, you might see expected results.  Let me know how it goes.
Zach C.
Field Engineer
Greater Los Angeles
(5,797 Views)
