Signal Generators
looking for a PCI sine wave generator : +-2v offset,10-20Khz anplitude 0-10V
hi please help be the best solution for the above specifications.
thank you....
(6,744 Views)
We actually have quite a few products that can acheive this.  I would recommend taking a look at this webpage.  That link goes through the options that you have for a PCI signal source.  A product like a PCI 5406 will be able to do what you want pretty easily.
Also, since your speeds are fairly slow you might even be able to use a DAQ device.  If you go onto this page.
http://www.ni.com/dataacquisition/
you will be able to find a list of our multifunction DAQ boards, which might serve the purpose.
Hope that helps.
Raajit L
(6,722 Views)
