Signal Generators
multi-channel analouge sig gen
Hey, I have a PXI-6723 32 channel AO card. I'm afraid I'm pretty new to labview so bear with me . I'm creating a sig gen to help test some equipment on MAST. I need to be able to send a sequence of square pulses one after the other on seperate chanels, for n channels (ie a pulse on chanel one followed by a pulse on channel 2..etc) as well as be able to output distinct waveforms (loaded from an archive) on distinct channels simultaneously (Ideally all 32, eventually scaling to 192). Is there a way to do this? I can create a voltage output task with 32 channels but I can't seem assign seperate waveforms to each channel without using different tasks. Is there a way to put distinct waveforms on individual channels with DAQ assistant?
Simon
(6,358 Views)
Hi Simon,
6723 falls under Multifunction DAQ card category. Please post under Multifunction card section
http://forums.ni.com/ni/board?board.id=250
Kalyanramu Vemishetty
Automated Test Systems Engineer
(6,349 Views)
