Signal Generators
ni-fgen create advanced arb sequence.vi
Has anyone used this FGen VI listed in the subject?  I am primarily confused about how the waveform handles are indexed.  In the example code I have, an array of waveform handles is generated from the VI that downloads binary waveforms to the 5431 I am using.  So my confusion could actually be centered around how the binary waveform is created from the .bin video file.
Quintin
(6,790 Views)
Quintin,
Where did you find that example program? I'm not seeing it in my copy of LabVIEW and I didn't find it in a quick search on the web. Also, I'm not sure what your question is about with respect to that example. You mention that you're confused about how the waveform handles are indexed, but what confuses you about that?
So let me know where you're seeing that example and specifically what your questions is and I'll see if I can help you clear things up some. Until then, have a great day.
Tyler S.
(6,752 Views)
Thanks for replying, but I already received some feedback via email support and have an understanding of the indexing, here's a link to the example though:
thanks,
Quintin
(6,748 Views)
