Signal Generators
rfsg finite IQ generation - signal keeps repeating
Is it possible to generate a finite signal from IQ samples?  I am generating an IQ data set containing a certain number of data samples and I want to send it to the RFSG so that it transmits it only once.  I cannot figure out how to stop the RFSG from repeating the same set of samples over and over again.  I am using Labview 8.5, 1065 PXI chassis, PXIe-5442 AWG, PXI-5610 Upconverter
(5,831 Views)
In order to perform finite generation with our RFSG devices you have to use scripted generation mode. There are examples that install with the NI-RFSG driver that accomplish this, specifically the example RFSG Finite Generation.vi. You can find this example along with others at Start»Programs»National Instruments»NI-RFSG»Examples»LabVIEW 8.5.
If you don't see this example, you may need to update your version of the RFSG driver to the newest version, which you can do HERE. Enjoy!
Chris
(5,819 Views)
